tigerrver
Cooler Replacement 220 SSI
 There has been a lot of discussion over the years regarding the igloo 25 quart cooler holder in the Chaparral line. I found an Engel 25 quart that fit almost perfectly. I had to remove the star-board blocks that were used to hold the igloo in place. This can be done by removing the entire holder by removing all of the perimeter screws. I then purchased some 1 inch stainless steel hold downs and a 40 inch Velcro strap. That’s about all there is to it. The Engel touches on each side, but the lid opens fine.
It's good to have options. The igloo is fine for day trips, but it's not something that stays nice looking for too long. Does the Engel stick out a bunch more than the Igloo?
Looks like it may stick out an extra 4" or so from the pics.
The Engel is 14 1/4 inches wide at the top and 12 1/2 at the bottom The igloo is 10 1/2 inches wide top to bottom. So it sticks out a little further.
