Scott21ss
Power outlets only working when plugged into shore
This is all new to me my first boat i have 3 plugs on board 2 are gfi one is not
when plugged in to shore evething works good when just on batterys nothing works not even panel lights up is this normal someone did install a inverter that connects right to the battery but wanted power in cabin too thanks 2003 21.5ss 5L mercury
Your outlets will only work when hooked up to shore power (110v) or if you have a generator, which I doubt you have on a 21.5ss.
Greg
Doubtful the inverter is connected directly to the AC side. You may have an inverter only on the non GFI outlet and the GFI protected ones are shore AC power
