whosurpopi
Yamaha tilt pin stuck
I got a 2003 f115 that is leaking tt fluid.  I tried to remove it, but the bottom pin is stuck.  It is the kind that has two bolts with washers holding both ends in, then an 8" pin that is supposed to slide out.  I have been beating it with a sledge, and also an air hammer.  Nothing.  I have taken the weight off with a strap, and sprayed the crap out of it.  I have tried heating it, and using freeze off.  Is there something you guys have found that works other then all this?
The forward pin remains in the housing, as you slide off the trim cylinders for clearance. The rear pin should slide out, but does not really need to.  W
1 minute ago, whosurpopi said:
I dont think we are talking about the same setup.  Yamaha outboard f115?   It has the upper pin, and the lower pin.  Upper pin is held in with a clip, then slides out really easy,  Lower pin is held in with two short bolts and washers.
https://www.crowleymarine.com/yp/CE969174/power-trim-tilt-assy-1-f115txrb-2003-115hp
Yep, thought you had one on the old Yamaha outdrives.
