LakeMichiganBoatLife
Chaparral Signature Leaking Water in Cabin?
Hello,  I have a 2002 Chaparral Signature 240 that I bought used 8 years ago.  The boat is still in really good condition and runs well!  I do have one reoccurring issue that for some reason this year has gotten worse.  Water is leaking up through a small hole (see picture), about 1 inch diameter, that is below the steps that go down into the cabin.  There is a small bilge pump right near this hole but I have never heard the pump turn on before nor is there a switch that triggers it like the bilge pump in the rear engine compartment.
I will arrive on the boat which is in a marina and the floor in the cabin will sometimes have up to an inch of standing water.  It is usually much less than this and more than likely it is dry.  One time recently I was loading the fridge and prepping the boat for a day out on the water and I see the water start to fill in the bottom carpet so I look under steps and water is pumping out of the this 1 inch hole.  I have no idea where or why this water would be coming from this??  This has probably happened on like 5 or more occasions just this summer.  In the past it probably happened about one every other year and very light so I didn't think much of it.  Now it has gotten to be more than annoying as it actually prevents me from using the cabin.  Does anyone know the purpose of this hole under the steps and why water would be coming back up from it?
Do you use the shower in the head? The forward pump is a sump pump to discharge the shower water most likely.
Why is there a fitting with no hose on it ?
Check the pumps float switch to make sure it is working.
Do you have A/C?
No I do not use the shower and no I do not have A/C.  That fitting is sealed by the way so it should not pose a problem.  The fitting connects to the sump area which is enclosed in a case.  But the water is coming from the hole in the floor...
Hard to tell from your pic what I'm looking at.  Does it have a forward bilge pump under the cabin steps?
He said it has a sump but the leak is not in that area...very confusing .. Maybe a larger picture of the area)...
On ‎10‎/‎4‎/‎2019 at 11:07 AM, LakeMichiganBoatLife said:
So you basically don't know where that water is coming from?  When you say "pumping out of that hole", is it actually spewing or spitting water as if it's being pumped out of another pump somewhere, or is it just coming out of it as in overflowing?  The answer will give us a better idea because you saying water is "pumping out of that hole" means something else somewhere else is pumping that water out of that hole.  Terminology is important so we can understand better because if it is "pumping" out of that whole. then it either needs a hose connected to that whole (and maybe that is why that sealed fitting mentioned before is lined up with it and there is a missing hose there that goes into that fitting.  All that, of course, depends on where that fitting leads to since you don't want to hook up a hose that will pump that water into somewhere you don't want it to end up.
Any idea where those fittings -- including the capped one -- lead to?  Thru-hull?  Bilge?  2002 I doubt you have a grey water system or something like that.  But let us know those 2 things first - is  it pumping or overflowing and where do BOTH those fittings lead to?
Could be just rain water accumulating in your forward keel and running under and coming out that hole instead of making it to the bilge pump.  Since you don't have AC and no one is using the shower and most of the time you discover this water is when you arrive to the boat at the slip, then it kinda rounds it down to either another system that uses cooling that is left on and is leaking, or water is entering from the lake/ocean through something that is broken and flooding the bottom and coming out that hole.  If it's pumping as in the definition of pumping, then it's coming from another source you need to find.
I have a 2002 signature 260 and get water in the same location. I suspect rain water getting in through the anchor locker. Should be the same set up as mine. I have the shower sump and a seperate foward bilge pump under the step. No way to turn on the foward bilge manually as it has a float switch. Had to change my foward bilge a couple years ago and I suspect your needs a replacement.  Mine never got high enough to get the carpet wet as the bilge did its job. Boats already in storage or I would have taken a pic for you,
Exactly, I don't know where the water is coming from.  The one time I actually saw water coming out of the hole with my own eyes, it seemed to be surging as to if it was being pumped however that could also be how the water was just overflowing out of the small hole?  I wish I could attach a bigger picture of the area, I tried, however this forum limits the size of attachments so I had to cut the original picture.  That forward bilge/sump is enclosed in a case and the sealed fitting is located on that case.  This is all under the cabin steps area.  If I put a hose into the hole and directed it in the enclosed bilge area would that actually work or would it still come up around the sides of the hose?
I am going down to the boat today and we have had quite a bit of rain since I last was there so I will see what happened and try and get some more pictures.
That's a heck of a lot of water, though.  Question is where is it coming from if it's surging out of that hole. That means A LOT of water is under the floor and the source needs to be found first and foremost.
Post whatever you have.  If you can get it on an image hosting site and in jpg format, then you can just paste the link and the big pic will show up like the first one you posted.
You can't access that forward bilge?  Is it under the steps or under the bed or forward berth seats?
Post as many as you can.  Something is terribly wrong if you're getting surging water like that.  And of course, can't have the cabin floor soaked under any circumstances.
Forward bilge???   If he is set up like I'm thinking he has a shower sump under his steps.
Are you sure the water is being 'pumped' into the area and not just sloshing around due to the movement of the boat? Is the item in the hole removable? What is it exactly?
By forward bilge I meant a forward bilge with a sump pump.  Sometimes they're located under the forward berthing whatever it may be, but then he said there's a tiny sump pump next to the hole that's spewing water under the step like most Chaps but hes never heard it run before and neither is the shower being used.  Maybe that's the problem and the pump is not pumping out that water which is probably just rain water from that one bad hose.
So we had a lot of rain this past week and there was no new water on the carpet.  It almost seems as if it accumulates over time and then eventually just overflows.  However, I do turn on my rear bilge in the engine compartment when I come down to the boat and have seen it overflow after even doing that.  I have attached a picture that you can see the enclosed case for the sump which I believe this is for the shower?  Again this is under the steps that going into the cabin.  It is not the forward berth seats.
It is not just sloshing around because the boat is stationary in the marina slip when it happens.
Phillbo hit it on the head already...there is a fitting there with nothing attached to it.  Check the parts manual to see if it identifies that area.  I would contact Chaparral as well and ask them what suppose to be there.  You don't have a fitting sitting there for no reason.  Something is missing..
No, he said the fitting with the missing hose is capped off... Also it would not account for the water coming up from below via the round thingamajig.... I'd love to get a better idea of what that round thing is and whats below it. Can it be removed?
Not on a lift.  Just in a slip so I guess it could move a little but it really doesn't all the much and the time I saw it happen it was just me and I wasn't jumping around.
I cannot find anyway to contact Chaparral but I am guessing that extra fitting would be in case I wanted to add an A/C unit?
I will see what happens it I try to pull that hole up from the floor.  Fingers crossed I don't sink ;)
Maybe plug the hole and see where the water migrates to next ?
On edit: I guess that would only tell your where it's going, not where it's coming from...... This is an interesting one.
Wow I've never seen that guide.  Pretty useful.  Thanks for sharing.
I tried pulling on the hole plug and it's not going anywhere.  In the guide it is definitely that are next to the shower sump and it seems like it is listed as shower drain.  However there is a drain also in shower/bathroom area so not sure if that's what it is referring to.  It would not make sense why I saw water coming back up out of a drain....
I think addressing the problem of the whole is secondary to the source of the water.   IIRC, you said the shower is not used nor is the sink or whatever else you have in the cabin, therefore it's either rain water draining coming in somewhere or someone is using a sink somewhere and the small bilge pump you also said that is near that area of the picture you took is not working and your carpet is soaked.   So you have a water intrusion problem you need to find first and foremost before doing anything with that hole, like why is the carpet soaked?  I would start there. There shouldn't be any water under that sump or bige pump spewing water out of it.
On ‎10‎/‎9‎/‎2019 at 10:31 AM, Phillbo said:
Though it was capped
 Why isn't there a hose going to the right side of that pump?  Looks like a hose should be on there and then attaches to the fitting on the deck.  Looks like that fitting on the deck where the water is coming up from is a drain from somewhere else on the boat (shower??).
No it was never solved.  The water still randomly comes up from the drain in the floor and floods the carpeting.  It actually was flooded in October when I went to remove it for the winter.  I am out of options as to who I can contact since Chapparal goes directly to dealers and dealers don't seem to care about older boats.  I am thinking to just plug the drain because having a flooded carpet every couple weeks is not enjoyable but I am not sure what else that might affect.
Lets look at it another way.  There are only a couple of sources of water.  First, the body of water your boat is slipped in.  Sources of water intrusion could be seal around a transducer, transom seal on out drive, inlet for cooling, inlet for head, rain or hose from washing boat.  Note that rain, or washing the boat may have a delay from time of rain event to when you see water as it water may be traveling down and around various structures in the boat.
Can you correlate the water with any rain events?  That is, if it rains, you have high probability of water?  Same with washing the boat.  Is there water in the aft bilge that could be making its way up front?  I think we can think through this and help identify the issue.  I'll look at the parts diagram to see if I can come up with some ideas.
Crack in the hull bottom ?  Marina fork truck dropped / poked it ?  Been there.
