Black Pearl
Volvo Penta Fuel Pump
Has anybody experienced this:  I have a 8,1 gi.  The other day I go to start the boat and a whining noice (sounded like the fuel pump) I know the sound because I had to replace this about 5 years ago.  But was at idle and once throttle was up it just shut down.  Started it up and same whining noice and at gave it some throttle and you can tell it was starving for fuel.  service department looked at it today and he couldn’t find a thing wrong.  fuel pressure is normal and no whining noice.  Drove boat for 30 minutes and no issues.  Is it possible,  this pump is going bad and then correct itself?  Mechanic is just guessing (maybe something got into the fuel causing the pump to over work causing the noise). He said he hears no whining).  I figured what’s the whining starts its bad period.  I hate to buy a plump at 2K and that not be it.
Black Pearl
Have you ever taken the entire fuel module apart and removed the black internal coating. That stuff can be the gift that keeps on pining, and it would seem a chunk got trapped in the fuel pressure regulator relief valve cavity for a time, dead heading and over-pressurizing the secondary fuel pump. Chances are it will happen again. W
Black Pearl
I have the same engine on mine and thankfully nothing yet on that crazy expensive fuel pump, but I'm expecting it at some point but maybe not, only because I think they stopped painting the inside by 2010, not 100% sure but something I read reminds me of that.
But, if you search YouTube for "fixing a Volvo Penta Fuel Pump," a couple of videos (that I've actually posted a few times for people with the same or similar problem) of a guy out of Florida who specializes in taking the entire fuel pump apart and not only cleaning the internal paint which causes most of these problems, but replaces a few parts with better ones and does it really cheap.  I think it's even under $100 that he does it.  He shows the entire process on the video so you can either do it yourself or send it to him and he does it and sends it back to you.  When I get back home later this evening, I'll find it and post it for you unless you find it before then.
Thanks,
I found the video!  Pretty interesting that he’s able to repair those.  I plan on spending sometime this weekend on the boat.  I am sure it will repeat itself and i would rather fix the problem sooner than later.  It seams that VP has plenty of issues with this.  Apparently, Carter is who makes the pumps and all they are doing is pointing fingers.  I thinks changed the part number 1/2 dozen times.  Each time the price goes up.  Thanks for the feedback.
The internet is loaded with cheap, knock-off pumps but I've yet to find anyone that has had luck with them. What I do not know is if the subsequent failures were a result of a poor quality replacements, or the fact that the entire fuel system was not cleaned during installation. Merc had a similar issue with their cool fuel modules and the newer ones are not coated internally.  Now the industry has returned to aluminum fuel tanks and a fuel return line that keeps a slip stream of cool gasoline returning to the tank in constant circulation, similar to an automotive application. W
so i experienced the same thing and this is what happened.
the fuel pump is easy to bump while you are working on other items such as oil changes, etc.  i apparently bumped the electrical plug, it was still connected but i jarred it slightly loose - this caused the LP and HP sides to not work and when i went to full throttle I heard that high pitched whine.  at first - it didn't effect the performance but very soon after the plug vibrated further loose and the engine was starved for fuel.  By pure luck and frustration, i disconnected the pump to get a better look and while doing so i noticed it wasn't fully connected.  i cleaned the contacts and bam- no more whine and fully functional.
from your description, you say it fixed itself.  i would suspect that contacts came loose - or at least rule that out as volvo fuel pumps are not cheap
If the noise returns and is not an easy fix, try re-furbishing the fuel cell yourself. I did mine and it is easy to do. Also as Wingnut stated, there are many "knock off" fuel cells being sold on ebay for as low as $200. You could go through several of them for the cost of one OEM one, might be worth a try.
Thanks for all the input!  Delaney - i will look for proper connection.  I had generator repair done that week and that’s When it occurred.  It was running fine prior to that.  It doesn't mean that the pump is ok, it could still be going bad.  That’s just an easy check.  I have owned the boat sine new (06) and i use nothing but Oem parts.  I was finally happy that i was able to get the Koehler running, of course it required replacing the catalytic converter.
On 2/13/2020 at 7:17 PM, Black Pearl said:
Thanks,
My two pump only had 160 hrs on them before they acted up. Another reason I am going to diesel.
