brirei Posted May 8, 2020 Share Posted May 8, 2020 Finally went through my nav lights, cleaned / lubed all contacts and replaced with LED bulbs. If you're interested, I found good stuff on marinebeam here's what I used: Quote Link to post Share on other sites
Stimpy Posted May 9, 2020 Share Posted May 9, 2020 I did the same thing a couple years ago in our Sig 290....here is my list if anyone's interested. SO much nicer with LED's!! Description part # Qty Purpose Web Site G4 Base Side Pins 10 LED Light Bulb 12V (WARM WHITE) 1109 15 cabin/head LEDWholesalers X-Beam side pin blue/cool white Bi-color G4 bulbs ILSPG4-09BC 2 arch 31mm (1-1/4") 4-LED Festoon Bulb (RED) FS-31-04-RED 1 nav Marinebeam 31mm (1-1/4") 4-LED Festoon Bulb (GREEN) FS-31-04-GRN 1 nav Marinebeam 31mm (1-1/4") 4-LED Festoon Bulb (BLUE) FS-31-04-BLU 1 court Marinebeam 31mm (1-1/4") 4-LED Festoon Bulb (WHITE) FS-31-04-CW 1 stern nav Marinebeam Wedge Base 15-LED Omni-directional Micro Tower (WHITE) WG-MICRO-CW 2 360 nav Marinebeam Sylvania LED dash mini bulb (BLUE) 194BZEVOLED 1 eyebrow court Autozone Quote Link to post Share on other sites
Youngz Posted May 9, 2020 Share Posted May 9, 2020 I’m looking for blue led bulbs to replace my current ones. I bet I can get those here too! Tanks for sharing. Quote Link to post Share on other sites
Youngz Posted May 9, 2020 Share Posted May 9, 2020 23 minutes ago, Stimpy said: I did the same thing a couple years ago in our Sig 290....here is my list if anyone's interested. SO much nicer with LED's!! Description part # Qty Purpose Web Site G4 Base Side Pins 10 LED Light Bulb 12V (WARM WHITE) 1109 15 cabin/head LEDWholesalers X-Beam side pin blue/cool white Bi-color G4 bulbs ILSPG4-09BC 2 arch 31mm (1-1/4") 4-LED Festoon Bulb (RED) FS-31-04-RED 1 nav Marinebeam 31mm (1-1/4") 4-LED Festoon Bulb (GREEN) FS-31-04-GRN 1 nav Marinebeam 31mm (1-1/4") 4-LED Festoon Bulb (BLUE) FS-31-04-BLU 1 court Marinebeam 31mm (1-1/4") 4-LED Festoon Bulb (WHITE) FS-31-04-CW 1 stern nav Marinebeam Wedge Base 15-LED Omni-directional Micro Tower (WHITE) WG-MICRO-CW 2 360 nav Marinebeam Sylvania LED dash mini bulb (BLUE) 194BZEVOLED 1 eyebrow court Autozone Wound the mini blue dash bulb be the one for courtesy lights? Quote Link to post Share on other sites
Stimpy Posted May 9, 2020 Share Posted May 9, 2020 35 minutes ago, Youngz said: Wound the mini blue dash bulb be the one for courtesy lights? Yes, it's the small eyebrow light by the cabin door on the port side. FS-31-04-BLU would be the one under the rear seat. Quote Link to post Share on other sites
drewm3i Posted May 10, 2020 Share Posted May 10, 2020 Good idea! Quote Link to post Share on other sites
MonacoMike Posted August 17, 2020 Share Posted August 17, 2020 Someone here should point out the obvious, the CG only approves fixtures, not bulbs. Therefore if the bulb is replaced with a bulb type not manufacturer recommend the light is no longer CG approved. It will not matter until it does. These are serious matters not to be taken lightly. A friend put in bulbs, the super bright LED sounds better, however the color was washed out to the point it looked like a white light in the distance. The lens was not made to diffuse LED light. Additionally the CG has a warning out concerning LED lights and VHF interference. You should test to be certain the LED lighting is not affecting your VHF performance. https://www.dco.uscg.mil/Portals/9/DCO Documents/5p/CG-5PC/INV/Alerts/1318.pdf?ver=2018-08-16-091109-630 Quote Link to post Share on other sites
Iggy Posted August 17, 2020 Share Posted August 17, 2020 2 minutes ago, MonacoMike said: Someone here should point out the obvious, the CG only approves fixtures, not bulbs. Therefore if the bulb is replaced with a bulb type not manufacturer recommend the light is no longer CG approved. It will not matter until it does. These are serious matters not to be taken lightly. A friend put in bulbs, the super bright LED sounds better, however the color was washed out to the point it looked like a white light in the distance. The lens was not made to diffuse LED light. Additionally the CG has a warning out concerning LED lights and VHF interference. You should test to be certain the LED lighting is not affecting your VHF performance. https://www.dco.uscg.mil/Portals/9/DCO Documents/5p/CG-5PC/INV/Alerts/1318.pdf?ver=2018-08-16-091109-630 With the above said too.... I found it easier just to replace the hole fixture. Keep in mind, that there potted so the contacts or connections can not rust up. Quote Link to post Share on other sites
