Yangjiang
The Working Principle of Solvent Extraction Plant:
he principle of solvent recycling machine is to take advantage of some organic solvents in the waste lubricating oil containing hydrocarbons and additives, oxidation products, sludge and other solubility different characteristics, under certain conditions, the waste oil additives, oxidation products, sludge and other impurities removed, and then distillation recovery solvent. This device can be used oil decompression hair oil, cutting line oil, black wood, machine oil, waste liquid pressure oil, transformer oil and other waste containing no solid particles oil one-time processed into performance close to the second type of base oil, hydrogenated oil chroma water white, color code below 0.1, viscosity, viscosity index, acid value, carbon residue, demulsification, pour point, saturated hydrocarbon and other indicators are at or near the level of 2 kinds of hydrogenated base oil. If it is used together with the distillation unit produced by our company, the refining effect will be better.
