albert miller Posted June 12, 2020 Share Posted June 12, 2020 Hey guys I have a chaparral 246 ssi surf 2018 and randomly when I turn on the speaker the system keeps on switching from mute to regular and it switches from bluetooth to aux without me doing anything. Does anyone have any ideas why this is happening? I've tried resetting the power or pushing the update button but nothing has worked so far. Quote Link to post Share on other sites
highhplowiq Posted June 12, 2020 Share Posted June 12, 2020 Sounds to me like the head unit is freaking out for some reason. Has it gotten abnormally wet or anything like that? It should still be under warranty with Chap if it is indeed going bad. Quote Link to post Share on other sites
albert miller Posted June 12, 2020 Author Share Posted June 12, 2020 It’s in a pretty secure compartment so it shouldn’t have gotten wet. Heading up north for the weekend any ideas on what I can try for a quick fix? Quote Link to post Share on other sites
dan02gt Posted June 12, 2020 Share Posted June 12, 2020 Make sure it's running the latest firmware. If you have any remotes it could be one of them. Quote Link to post Share on other sites
albert miller Posted June 16, 2020 Author Share Posted June 16, 2020 how would i check the firmware? There are no remotes its just the touch screen for controls Quote Link to post Share on other sites
albert miller Posted June 16, 2020 Author Share Posted June 16, 2020 I also noticed yesterday that it usually has more problems when the volume is turned up more, but i'm not positive about that yet. Quote Link to post Share on other sites
dan02gt Posted June 16, 2020 Share Posted June 16, 2020 What model is the head unit? Quote Link to post Share on other sites
highhplowiq Posted June 19, 2020 Share Posted June 19, 2020 I would start searching for loose wires/connections. Quote Link to post Share on other sites
Iggy Posted June 20, 2020 Share Posted June 20, 2020 Disconnect your remotes one by one and see if the problem goes away. I bet thats the problem. Quote Link to post Share on other sites
Ran-Man Posted June 22, 2020 Share Posted June 22, 2020 Sounds like not enough power going to the head unit. I believe there are two hot wires, red and yellow. Red is the battery and yellow is accessory I believe. Make sure each have 12 volts.Each of those wires should have their own fuse. Mine had a similar issue. Quote Link to post Share on other sites
