Telmor Posted June 13, 2020 Share Posted June 13, 2020 Recently i had to replace my engine starter and in the process the fuel pump turned on and now wont shut off even if i take the key out of the ignition. The engine has the same problem, whenever i turn it on it on it runs fine but wont shut off with the key. thought the diode might be the problem but i replaced it and it did nothing. Quote Link to post Share on other sites
Iggy Posted June 13, 2020 Share Posted June 13, 2020 I would go over your work. You must have miswired something. Quote Link to post Share on other sites
