Boban
Signature 330 fuel tank leak
Good morning everyone,
I am the owner of a Chaparral Signature 330 built in 2007,  that is having an issue with the fuel tank (probably a hole in it/ broken).
I read that someone on the forum has already had this problem.
I need to substitute the tank and in order to do that I urgently need the stringer installation scheme of the boat. To proceed with the work I need all the measures regarding the tank (inches/ centimeters) and the exact position of it in the boat (in order to cut the fiberglass to access it).
Can someone help me?
Thank you in advance.
Greetings from Italy
Matteo
TRy contacting Chaparral directly ?  Might get lucky
Or try www.cecilmarine.com  They are a excellent company.
Thanks for your attention!  Surely the work will be developed by a pro. But in any case he doesn't know perfectly the boat and the size of the tank. Chaparral sent me these schemes but I can't understand how they wrote the measures. Can you understand? Can you turn them into centimeters?
Sorry but here in Italy we use a different metric system.
The deck will be destroyed & so is  / will be the tank...………….. The person should know all the safety steps & done several other tank removals.  None that caught fire or exploded during the repair.   Not much else to be said about replacing the tank.
