JohnB246
Rusty water coming from outdrive intake holes
I just noticed a rusty residue coming from intake holes on my lower unit.  Maybe I should be draining the outdrive each time I use it (but I don't).  The boat is dry stored in my side yard.  This boat only has 140 hours on it and it's a 2007 SSI 246, with a 350 Mag.  Mercruiser Bravo III.  I purchased it with 110 hours on it and have used it 10 times in the last 6 months.  I use it in fresh water and, so I'm told, so did the previous owner.  I did just have it serviced (yearly service).  And it wasn't showing this rust before the service.
Is this something I should be concerned with?
Are you sure it's rusty and not just calcium? Our heat does strange things.... Who did the annual?
BTW, I'm in Scottsdale too, if you need a good mechanic I have a friend that has a shop at his house and is Merc certified. He got tired of the stealership cluster and  has been maintaining a lot of my friends boats for years.You can trust him to treat you like a person and not a number.
If you would pass your friend's contact info, that would be great.
It looks like rust to me.  Anybody know what causes this?
I see comments like, 'yes' be worried.  How worried?
Not to me or any boats I have seen in the storage areas.
Looks like a powerful acid is draining out of your engine to cause that much rust every year.  I have a 1986 & a 1990 O B withthousands of hours on each  Neither has a rusty nose bleed. from winter storage
Antifreeze is yellow, green or pink.
