Jesper schønnemann Posted July 27, 2020 Share Posted July 27, 2020 Hello need a litle help. My Signature 276 year 2006 have no power at my 3 receptacles. when I had shore power . The Refeig, Stove and Microwave has power. Maybe it is a fuse but where ? Have a nice day from Denmark. Quote Link to post Share on other sites
Bt Doctur Posted July 27, 2020 Share Posted July 27, 2020 more likely you have a hidden ground fault outlet (GFI) that is first in line protecting the other outlets. Most times installed in a damp location, Quote Link to post Share on other sites
Iggy Posted July 27, 2020 Share Posted July 27, 2020 33 minutes ago, Bt Doctur said: more likely you have a hidden ground fault outlet (GFI) that is first in line protecting the other outlets. Most times installed in a damp location, Yep! and I would check the wiring after that. Quote Link to post Share on other sites
Jesper schønnemann Posted July 28, 2020 Author Share Posted July 28, 2020 Hi Bt Thanks for reply. But there are still 220 v power at Refeig, Stove and Microwave ! Do you have any idea where I can find “ Ground outlet GFI ? Thanks Jesper Quote Link to post Share on other sites
Jesper schønnemann Posted July 28, 2020 Author Share Posted July 28, 2020 Hi Bt Thanks for reply. But there are still 220 v power at Refeig, Stove and Microwave ! Do you have any ideer Quote Link to post Share on other sites
Iggy Posted July 28, 2020 Share Posted July 28, 2020 Looking at the pic I dont think you have a GFI outlet. But I was thinking you may have some form of one. My wife comes from France and we visit there every few years. I have never seen one there. In the U.S. it is required by law (every state in the U.S. is a little different) to use a GFI outlet in wet locations. This is a safety device that helps stop electacutions from happening. Case on point, if you dropped a hair dryer in the tub and some one was in it. Chances are they would be dead. But with a GFI outlet in the bathroom, chances are they would be alive. In milliseconds it turns the power off. I would look at the wiring, both at the breaker and outlet. Quote Link to post Share on other sites
cyclops2 Posted July 28, 2020 Share Posted July 28, 2020 Your boat is probably wired by E U standards. I see you use 50 HZ frequency. Call a Denmark dealer for help. wiring could be different also. Quote Link to post Share on other sites
