Yuneng
EHC Fire-Resistance Oil Purification Machine
According to the characteristics of Phosphate Ester Fire-Resistant Oil (fire resistant oil), we designed EHC Vacuum Fire-Resistant Oil Purifier(also called Fire Resistant Oil Filtration Machine). Yuneng adopts technologies of deacidification filtration, anti-sedimentation, mixing coagulation separation, vacuum drying, superfine filtration, etc., it efficiently removes acid, pigment, moisture, gas and impurities from oil. A series of technical problems such as anti-fuel compatibility, thermal stability, hydrolytic stability, solvent effect, specific gravity characteristics and toxicity have been solved by Yuneng. It is mainly used for services of phosphate ester fire resistant liquid (oil) or other hydraulic systems with the fire resistant oil as the working medium. it can be online working and oil-filling.
Fire resistant oil is a kind of  corrosive oil, so the machine body uses the special metal materials which are compatible with fire-resistant oil, it combined with technologies of vacuum dewatering, degassing, multi-stage filtration system and new adsorbent to ensure treated oil achieve new fire-resistant oil properties.
Yuneng's products enjoy a fairly big market share and have become a famous brand in medium- and high-grade oil treatment equipment. If you have any questions or needs, please feel free to contact us.
