Yuneng
Turbine Oil Purifier and Other Lubrication Oil Purifier
Vacuum Lube Hydraulic Oil Purification System is designed for purifying hydraulic oil, anti-wear hydraulic oil, aviation hydraulic oil, turbine oil, gear oil, refrigerating oil, heat treatment oil, internal combustion engine oil, etc. It can quickly remove impurities, moisture, gas and reduce acid value, finally, it restore oil viscosity, flash point and oil performance of lubricating oil. Yuneng's Hydraulic Oil Purification System is widely used in electric power, chemical industry, metallurgy, transportation, mining, machinery, cement, manufacturing, food and other industries.
During the use of lubricating oil, oil pollution may occur due to pressure, friction, environment, etc. As pollution increases, the viscosity and acidity of the oil will change, and moisture will increase, leading to equipment failure. Mixing the residual contaminated oil in the equipment circulation system with new oil will reduce the service life of the new oil. Therefore, in order to prevent oil pollution and prolong the service life of the oil, it is necessary to quickly remove pollutants and oxides formed in the oil.
Yuneng's lubricant oil purifier is specially used for various substandard lube oil cleanings, such as turbine oil, mechanical oil, hydraulic oil and cooler oil. According to the nature of the lubricating oil, the vacuum oil purifier manufactured by Yuneng can quickly remove water, gas, particles and impurities in the contaminated lubricating oil, thereby cleaning the lubricating oil and ensuring the quality and standard parameters of the oil. This will ensure that the machine's lubrication system reaches normal working levels and prolongs the mechanical life. In addition, the oil can prolong the service life of the oil in each cycle during the purification process, so it can save the replacement cost of new oil.
