Yuneng
Yuneng's Oil Moisture Tester
Yuneng's YN-809A/B/C Oil Moisture Tester is specially designed for the measurement of water content in oil. it can be portable or online use. They are certified in accordance with the regulations of the “Germanischen Lloyd (GL)” and therefore can be utilized in the maritime field as well.
The Oil Moisture Tester is a microprocessor-based instrument for the measurement of moisture in terms of water activity for example in the lubrication of circulation systems or in transformer oil. The transmitter incorporates a capacitive thin-film sensor. The operation of the sensor is based on changes in its capacitance as the thin polymer film absorbs water molecules.
