mcmac73
180ssi bilge pump replacement
2005 180 ssi, bilge pump runs non stop but doesnt pump, float is functioning , I can reach it and pump will stop, how do I reach the pump and remove it? does it just snap in? It was replaced about 4 yrs ago and the mechanic said the new one fit right into the original housing, no idea what it looks like?? anybody changed one?
If you want a snap in ? you need to remove the pump to get make & model ?Not which colored lead goes to the pump terminals.  Take a picture . Loosen the hose clamp on the pump hose.That is about it.  Your problem is JUNK blocking the water in or out.   Turn the pump ON & OFF with the dash switch.   Get lucky.  :)
