cadeco Posted August 7, 2020 Share Posted August 7, 2020 Hi Guys. My port motor turns but does not start. Let me explain: I Had the boat on the water and that motor would run idle as a swiss clock but when trying to accelerate it would die. A mechanic told me that the problem was with the sensor at the distributor ( very expensive little part). Well he changed the sensor and replaced the kit of the carburetor together w/ the spark plugs. After all of that the motor now cranks/turns but does not start. He asked me twice for the kill switch and I have no clue if the boat even have one. I need help w/ that -- Anyone know if the 2850 SX has a kill switch ? and if yes , Where is it ?- If not, What could be the culprit ? Thanks Very much !!! PS: The other motor works fine ! Quote Link to post Share on other sites
Bt Doctur Posted August 7, 2020 Share Posted August 7, 2020 what motor, what drive, is there spark from the coil? is there 12v at the coil? MOB or safety lanyard on the dash. shuts motor off if you fall overboard Usually a Red button or small red switch https://duckduckgo.com/?t=ffab&q=lanyard++safety+switches&atb=v224-1&iax=images&ia=images Quote Link to post Share on other sites
Phillbo Posted August 7, 2020 Share Posted August 7, 2020 Look below the throttle.... What year is the boat? I would find a new mechanic if he can't locate the kill switch if equipped. Quote Link to post Share on other sites
cyclops2 Posted August 7, 2020 Share Posted August 7, 2020 Sure sounds like a person removed the switch & connected the wires. Wires have come apart ? Quote Link to post Share on other sites
ramoszx12r@comcast.net Posted August 7, 2020 Share Posted August 7, 2020 5 hours ago, Phillbo said: Look below the throttle.... What year is the boat? I would find a new mechanic if he can't locate the kill switch if equipped. I agree with Phillbo. Quote Link to post Share on other sites
drewm3i Posted August 8, 2020 Share Posted August 8, 2020 I think he forgot to hook something back up...verify the coil wire is attached. Make sure the plug wires are hooked up properly to each cylinder, etc. That boat probably doesn't have a kill switch. Quote Link to post Share on other sites
Denny Posted August 8, 2020 Share Posted August 8, 2020 1 hour ago, drewm3i said: I think he forgot to hook something back up...verify the coil wire is attached. Make sure the plug wires are hooked up properly to each cylinder, etc. That boat probably doesn't have a kill switch. I was told years ago if you want to find out what is wrong, start with looking where someone has worked on it. Denny. Quote Link to post Share on other sites
drewm3i Posted August 8, 2020 Share Posted August 8, 2020 19 minutes ago, Denny said: I was told years ago if you want to find out what is wrong, start with looking where someone has worked on it. Denny. Sound advice! Quote Link to post Share on other sites
ramoszx12r@comcast.net Posted August 8, 2020 Share Posted August 8, 2020 39 minutes ago, Denny said: I was told years ago if you want to find out what is wrong, start with looking where someone has worked on it. Denny. That is for sure.I start to do my own mechanic work because bad work from the so call profesional. Quote Link to post Share on other sites
cyclops2 Posted August 8, 2020 Share Posted August 8, 2020 The difference between a amateur & a professional. You do not know when the pro has overcharged you. Quote Link to post Share on other sites
dmitri santo Posted February 9 Share Posted February 9 Your articles are inventive. I am looking forward to reading the plethora of articles that you have linked here. Thumbs up! CNPR Program Quote Link to post Share on other sites
pivoco4730 Posted February 17 Share Posted February 17 Persons appreciate shopping for amazing, appealing, fascinating and from time to time attractive aromas for them selves and pertaining to others. This can be executed conveniently along with inexpensively in an on-line perfume shop. 꽁머니 Quote Link to post Share on other sites
rseolink Posted February 18 Share Posted February 18 Good post but I was wondering if you could write a litte more on this subject? I’d be very thankful if you could elaborate a little bit further. Appreciate it! 토토사이트 Quote Link to post Share on other sites
rseolink Posted February 20 Share Posted February 20 Succeed! It could be one of the most useful blogs we have ever come across on the subject. Excellent info! I’m also an expert in this topic so I can understand your effort very well. Thanks for the huge help. motorcycle accident attorneys Quote Link to post Share on other sites
dmitri santo Posted February 22 Share Posted February 22 You understand your projects stand out of the crowd. There is something unique about them. It seems to me all of them are brilliant. 먹튀검증 Quote Link to post Share on other sites
rseolink Posted February 22 Share Posted February 22 This article is an appealing wealth of informative data that is interesting and well-written. I commend your hard work on this and thank you for this information. You’ve got what it takes to get attention. Gái Checkerviet Quote Link to post Share on other sites
rseolink Posted February 24 Share Posted February 24 read more click here website read more click here website read more click here website read more Quote Link to post Share on other sites
dmitri santo Posted March 1 Share Posted March 1 Your post has those facts which are not accessible from anywhere else. It’s my humble request to u please keep writing such remarkable articles Full Circle Health careers Quote Link to post Share on other sites
rseolink Posted Tuesday at 12:15 PM Share Posted Tuesday at 12:15 PM Nice post! This is a very nice blog that I will definitively come back to more times this year! Thanks for informative post. greengeeks login Quote Link to post Share on other sites
