Jw1125 Posted August 24, 2020 Share Posted August 24, 2020 Just picked up a 1995, 1830SS with a little over 100, yes one hundred, hours on it. The previous owner didn’t use it the last two years except for about 5 hours a year. anyways, It starts when I choke it, and keep the throttle about 50%. But, it still only runs at about 800RPM with it choked. I let it run today for about 10 minutes at that rate so it was warmed up. As soon as I ease off the choke it dies. Won’t start in neutral with no choke either. Just trying to get some ideas about what it might be? Mercruiser 4.3 LX Quote Link to post Share on other sites
Iggy Posted August 24, 2020 Share Posted August 24, 2020 Have you done a tune-up? Replaced fuel filters, cap, rotor, wires and alike Quote Link to post Share on other sites
SterndriveEd12 Posted August 24, 2020 Share Posted August 24, 2020 Drain the fuel from the tank. The fuel is stale. Always start with fresh fuel. Quote Link to post Share on other sites
Jw1125 Posted August 24, 2020 Author Share Posted August 24, 2020 Iggy, I ordered all of the above and will be replacing them this week, I guess that would have been smart of me to mention in the original post. Just was curious if there was any other tips. I’ll try some fresh fuel as well! Quote Link to post Share on other sites
cyclops2 Posted August 24, 2020 Share Posted August 24, 2020 Drying out gasoline in the fuel system causes a need for more choke. It can also be the idle is adjusted so LEAN that it stalls as the throttle is moved to any higher opening. It can be so sensitive that it will not run as weather changes. I did that to my 1996 Evenrude 30 hp. I forgot to use some Seafoam this year. I turned the idle mixture OUT a 1/4 more of a turn. Runs perfect again. Some carbs are that critical. Carefully check replace the sparkplugs. Have the auto place LOOK UP the correct PLUG NUMBERS. You may have the wrong ones in the engine now... Replace the distributor & rotor Quote Link to post Share on other sites
Jw1125 Posted August 24, 2020 Author Share Posted August 24, 2020 So I’m going to get the fuel drained (of course it’s about 3/4 full), spark plugs, fuel filter, distributor cap and rotor, then try it from there. If it still runs rough I’ll adjust the idle mixture screws. Hopefully with all that she’ll be good! What kind of fuel additive do you guys usually use? Quote Link to post Share on other sites
cyclops2 Posted August 24, 2020 Share Posted August 24, 2020 Seafoam.......... DO NOT PUT IN E-10 in a old unused boat !! E-10 ....WILL WILL DISOLVE ALL the Varnish in ALL the fuel system at ONCE !! BEEN there more than 1 time. Stay with NON E-10 for the first tank & Seafoam. It disolves Varnish SLOWLY. The carb can pass slowly dissolving Varnish easily. Quote Link to post Share on other sites
cyclops2 Posted August 24, 2020 Share Posted August 24, 2020 Does the choke open fully after running long enough ? You will be adjusting the mixture screw as the system cleans out. Do you have a 2 barrell carburetor ? Quote Link to post Share on other sites
Jw1125 Posted August 24, 2020 Author Share Posted August 24, 2020 Cyclops, thanks for the tips and info on the sea foam and everything. The choke does open, it just idles real low and more on the rough side Quote Link to post Share on other sites
cyclops2 Posted August 24, 2020 Share Posted August 24, 2020 Well There is a accelerator pump on many 2 throat carbs to help solve your problem. It may be worn out . Or misadjusted. That will cause your symptoms. Is there a metal tag on the carburator ? can you take some pictures of the throttle sid of the carb ? Quote Link to post Share on other sites
cyclops2 Posted August 24, 2020 Share Posted August 24, 2020 Have you turned the adjustment screws on the carb ? Have you moved the linkage to any of the different holes ? Have you moved the distributor around ? Quote Link to post Share on other sites
Jw1125 Posted August 24, 2020 Author Share Posted August 24, 2020 It’s a 4 barrel. I only had a little bit of time this weekend to mess with it but I haven’t adjusted any linkages or idle screws yet. I had just enough time to run it to operating temp to see if it would make it better. I’ll get some pictures as soon as I can and post them up! I’m thinking it’s bad gas and just needing a tune up cause it only has 105 hours, just needs more tlc and run time Quote Link to post Share on other sites
cyclops2 Posted August 24, 2020 Share Posted August 24, 2020 Does the carb have mechanical linkage to open the secondary ? Or vacuum setup ? Are the secondaries open the slightest bit ? is yes? that is your problem / part of it. They need to be PERFECTLY shut closed. No leaking of any air. Quote Link to post Share on other sites
