SonOne Posted September 13, 2020 Share Posted September 13, 2020 I have a pretty clean 2014 SSI with only 120 hours. Based on the gauge set up - I do not see room to add a Navi/map screen in the dash. Any recommendation on where to add the equipment. Suggestions on where I can possibly do it and keep the look "factory". Any pics you can share of your set up would be appreciated. Thanks in advance. Quote Link to post Share on other sites
dan02gt Posted September 13, 2020 Share Posted September 13, 2020 What SSI? I have a Garmin Echomap 74 in mine. Quote Link to post Share on other sites
willbaker13 Posted September 13, 2020 Share Posted September 13, 2020 I have a 2013 246 SSI with a Garmin 530 GPS that sits right in the middle of the dashboard. Quote Link to post Share on other sites
SonOne Posted September 16, 2020 Author Share Posted September 16, 2020 On 9/13/2020 at 5:42 PM, dan02gt said: What SSI? I have a Garmin Echomap 74 in mine. 216 widebody. Where is it located at? And thanks for the response Quote Link to post Share on other sites
dan02gt Posted September 16, 2020 Share Posted September 16, 2020 There should be a removable plate center of your dash where you can install one. It probably has two gauges in it now. Quote Link to post Share on other sites
SonOne Posted September 16, 2020 Author Share Posted September 16, 2020 Thanks dan02gt. I checked and you are right...the center panel comes off with the two gauges. Question - is there a Chaparral replacement panel - one that fits a navigation system. Just curious..thanks huge help. 3 hours ago, dan02gt said: There should be a removable plate center of your dash where you can install one. It probably has two gauges in it now. On 9/13/2020 at 5:42 PM, dan02gt said: What SSI? I have a Garmin Echomap 74 in mi Quote Link to post Share on other sites
Iggy Posted September 16, 2020 Share Posted September 16, 2020 Personally, I would mount the biggest GPS unit that I could. Meaning, ether in front of the gauges or on top of the helm. When your doing over 20 knots, small screens are very hard to read. Quote Link to post Share on other sites
SonOne Posted September 16, 2020 Author Share Posted September 16, 2020 Thanks Iggy Quote Link to post Share on other sites
dan02gt Posted September 16, 2020 Share Posted September 16, 2020 49 minutes ago, SonOne said: Thanks dan02gt. I checked and you are right...the center panel comes off with the two gauges. Question - is there a Chaparral replacement panel - one that fits a navigation system. Just curious..thanks huge help. So mine came with a old Garmin 520 installed in it. I took that out and had a new plate made out of black plexiglass that fit the hole perfectly. I installed my Garmin Echomap in that. Around $500 for everything. I’ll see if I can upload a picture. Quote Link to post Share on other sites
dan02gt Posted September 16, 2020 Share Posted September 16, 2020 Here's a picture of mine. Quote Link to post Share on other sites
SonOne Posted September 16, 2020 Author Share Posted September 16, 2020 Thank you sir!!! Looks great. Quote Link to post Share on other sites
