DLC
2019 Vortex gas gauge issues.
Any idea if you can calibrate the gas gauge with the Medallion Viper ll? My gauge reads just above 1/2 when full.
There’s been no “fix”. All the Vortex’s have that same issue. My alarm hits at 1/4 tank and is “full” at 3/4. Dealer says there’s no fix. There’s a FB Vortex group that all have the same issue, unless you drop the front of the boat on the ground at the gas station.
USCG   CAN get a RECALL on a safety item like that.  I guess no one knows that USCG has that much power to protect you on the water.
Can you install a MPG system in the Vortex boats ?  That should / could give MPG & gallons used / left in the tank ? Do thy have a manual reset at each refilling ?
It's been a year since I've shrink wrapped my Vortex 203 so, I'm going from memory.......I thought the display had the ability to produce statistics such as that.
