Yuneng
Necessary Of Transformer Oil Degassing
The necessity for transformer oil dehydration and degassing is known for a long time. Transformer oil is used in power equipment where it provides cooling and insulation protection. Over time aggregated moisture, gasses and solid particles can seriously affect these properties. To remove moisture, gasses, and solid particles transformer oil filtration plant needs to be used.
Transformer (Insulating) Oil act as a medium for insulation in the transformer, circuit breaker, high voltage instruments, etc. Transformer Oil is required to be filtered before use and even filtration is required after periodical time.
Filtration helps in removal of Moisture content, Dissolved Gases, Acidity, Sludge, Corrosion and other unwanted impurities, thus it helps transformer oil to improve its dielectric strength and Moisture content removal in transformer oil.
