Wingsy Posted October 14, 2020 Share Posted October 14, 2020 Recently bought a 2007 Sig 290. Two Volvo 260hp engines. Super clean and well maintained. I thought I would love it. I'm kinda new to boating, having owned a 19-ft Bayliner many tears ago. But disappointment settled in when I gassed up and loaded several people on board. At full power the boat would not get on plane (props full down, trim full down). Plowed thru the water for well over minute and I was about to give up when it slowly started to get up on the water. Once on plane everything was fine. But what the heck? This thing should get itself going with no problem, right? Is this to be expected? Please tell me I have a problem that can be fixed. I appreciate any suggestions. Quote Link to post Share on other sites
2004lebanshee Posted October 14, 2020 Share Posted October 14, 2020 Might be expected. I have a buddy with a 30 foot sea ray with 4.3 twins. Fully loaded with adults it can't plane. Miserable to ride on long range fully loaded. 4500rpm and throwing the biggest wake on sandusky bay. Quote Link to post Share on other sites
cyclops2 Posted October 14, 2020 Share Posted October 14, 2020 State the rpms of EACH engine. I would NOT TRUST the boats tachometer gauges until checked out. Water temperature of engines . Also a HAND HELD GPS MPH reading. What size are the engines ? what series ? Where do you buy the gas ? Marina ? People ahead of you may have put on the wrong or had the props TUNED incorrectly Engines have had ALL ignition & fuel system old enough parts replaced in the last 50 hours ? Could be cleared up with a FULL Maintenance job. It does happen. Quote Link to post Share on other sites
paulswagelock Posted October 14, 2020 Share Posted October 14, 2020 What outdrives, single or dual prop? What pitch props? Need to know max rpm at WOT with a light load. Could drop pitch potentially and fix the issue. Quote Link to post Share on other sites
Wingnut Posted October 14, 2020 Share Posted October 14, 2020 Is there any drive lower gear case corrosion at the intersection between the front of the prop hub ring and the drive itself? missing metal there allows exhaust gasses to sneak out and ventilate the prop resulting in greatly reduced thrust. Also, what is max achieved RPM? Could have a prop bushing slipping but I doubt it as it would have likely given up all together by now. W Quote Link to post Share on other sites
Phillbo Posted October 15, 2020 Share Posted October 15, 2020 Move the fat girls forward..... Then call Hill Marine and let them advise you. Probably a set of the 4 blade props will help. Quote Link to post Share on other sites
2004lebanshee Posted October 15, 2020 Share Posted October 15, 2020 32 minutes ago, Phillbo said: Move the fat girls forward..... Then call Hill Marine and let them advise you. Probably a set of the 4 blade props will help. Funny you said that. We did that. Quote Link to post Share on other sites
jeffk Posted October 15, 2020 Share Posted October 15, 2020 I had the same boat with twin v6 225 hp and with full gas water and 4 adults..(2 fatties) it planed fairly quick. Try taking the boat out yourself and see how it runs. I actually agree with clops....scary. You may want to have your props tuned. As you are a new owner a full maintenance will give you a baseline. Good luck, this will get fixed and you will enjoy the boat. . Quote Link to post Share on other sites
Phillbo Posted October 15, 2020 Share Posted October 15, 2020 40 minutes ago, 2004lebanshee said: Funny you said that. We did that. Sorry to hear about your boat load of fat girls Quote Link to post Share on other sites
Denny Posted October 15, 2020 Share Posted October 15, 2020 2 hours ago, Phillbo said: Sorry to hear about your boat load of fat girls Nothing to be sorry for, he just has more to love. Denny. Quote Link to post Share on other sites
Rambo Posted October 15, 2020 Share Posted October 15, 2020 On 10/14/2020 at 5:38 PM, Wingsy said: At full power the boat would not get on plane (props full down, trim full down). Plowed thru the water for well over minute and I was about to give up when it slowly started to get up on the water. Once on plane everything was fine. Try a different approach: set the drive to various positions between 50-75% down, where 50% is the floating boat level. Keep the tabs all the way down as you had them. A boat needs forward thrust and speed to plane, and the drives all the way down try to lift the stern at the cost of forward thrust and speed. Let the tabs do the lifting. The faster the boat goes the more lift tabs will generate. Once on plane with a reasonable load and under normal conditions, set the drives to be more less parallel to the boat's forward motion. Keep adjusting up and down till you hear the engine running smoother and the RPM getting higher aka a sweet spot. Quote Link to post Share on other sites
cyclops2 Posted October 15, 2020 Share Posted October 15, 2020 I forgot the most important thing. How level is the boat when everybody is in it ? have someone .............OUTSIDE............. the boat look at the boat and guide you to ORDER PEOPLE TO SHIFT AROUND to level the boat . Too much weight bow or stern will cause that problem to get on plane.....Fast enough.......... USCG used to use 10 people. EACH ONE was 135 pound weight. My 2002 186 SSI with 5.0L V8 Could not lift up 6 + 200 pound seniors with the heaviest on the bench seats in 3 to 4 foot waves with the 50 mph prop on. I put on a no Blow Out prop and a floored WOT start was a couple of seconds to a fast plane. The PROP is super important with heavy loads. I do not have any lifting plates.. I do jump into the water & change props for the load in the boat. 5 minutes at most with a Alpha . Single prop. drive. Dual props are a help. But a single prop drive has UNLIMITED Diameter , PITCH, CUPPING and rake available. A twin engine boat should only have single props. Quote Link to post Share on other sites
brick Posted October 15, 2020 Share Posted October 15, 2020 Any chance the boat is full of water? How did the boat run when you tested it before buying? Can it get on plane easily when lightly loaded? Engine RPM and speed data is needed. This boat with twin 5.0 ‘s should be able to plane easily. Quote Link to post Share on other sites
2004lebanshee Posted October 15, 2020 Share Posted October 15, 2020 12 hours ago, Phillbo said: Sorry to hear about your boat load of fat girls Haha. Well I was with my wife who is not fat. Really non of them were. We had all the guys get in the bow. Didnt matter. Quote Link to post Share on other sites
2004lebanshee Posted October 15, 2020 Share Posted October 15, 2020 3 hours ago, cyclops2 said: I forgot the most important thing. How level is the boat when everybody is in it ? have someone .............OUTSIDE............. the boat look at the boat and guide you to ORDER PEOPLE TO SHIFT AROUND to level the boat . Too much weight bow or stern will cause that problem to get on plane.....Fast enough.......... USCG used to use 10 people. EACH ONE was 135 pound weight. My 2002 186 SSI with 5.0L V8 Could not lift up 6 + 200 pound seniors with the heaviest on the bench seats in 3 to 4 foot waves with the 50 mph prop on. I put on a no Blow Out prop and a floored WOT start was a couple of seconds to a fast plane. The PROP is super important with heavy loads. I do not have any lifting plates.. I do jump into the water & change props for the load in the boat. 5 minutes at most with a Alpha . Single prop. drive. Dual props are a help. But a single prop drive has UNLIMITED Diameter , PITCH, CUPPING and rake available. A twin engine boat should only have single props. 3-4 foot waves on a 18 foot boat and your trying to get on plane? Seems crazy. Not to mention they were seniors? Quote Link to post Share on other sites
cyclops2 Posted October 15, 2020 Share Posted October 15, 2020 Chickens you are. Do you really think that load was going to plane ? Quote Link to post Share on other sites
Wingsy Posted October 15, 2020 Author Share Posted October 15, 2020 I appreciate everyone's replies. I've got several things to check out now. Quote Link to post Share on other sites
TexasPilot71 Posted October 15, 2020 Share Posted October 15, 2020 1 hour ago, Wingsy said: I appreciate everyone's replies. I've got several things to check out now. disregard. I mis-read the post. Quote Link to post Share on other sites
vanhalen80 Posted October 16, 2020 Share Posted October 16, 2020 I had a similar problem with my 2006 chap 276 w dual f-4 props and a single volvo 5.7 gxi... turned it I needed the injectors cleaned... cost: 350 total. I could never get the RMs past 3800.. after cleaning, it revs to 5k and actually had the boat up to 41.6mph the other day Quote Link to post Share on other sites
Larry Cole Posted October 24, 2020 Share Posted October 24, 2020 As some will remember, I had the same problem with a 2015 Sig 290. I did contact Hill Marine. I went from 24 down to 20 on the props.The boat now planes with a full load in less than 10 seconds with out using trim tabs. Quote Link to post Share on other sites
cyclops2 Posted October 24, 2020 Share Posted October 24, 2020 So there are at least 2 EXCELLENT prop retailers to help you get the best props for a sluggish planning loaded boat. Hill Marine or Propgods. call both for selection and pricing. Check out both of their TESTING of different props without buying everyone you want to test. Quote Link to post Share on other sites
bschuster Posted October 27, 2020 Share Posted October 27, 2020 Start out at a slower speed until you pick up a little speed then go full throttle. Full throttle at a dead stop buries the stern and lifts the bow and you will never plane. Most important is load distribution. Unless you want to spend money on new props. Quote Link to post Share on other sites
cyclops2 Posted October 27, 2020 Share Posted October 27, 2020 I can positively state That a prop built for thrust AND grip / no slip......... WILL keep my 2002 186 SSI with a 5.0 V 8 PERFECTLY LEVEL from a floored dead stop. There is NO NO bow lift . The boat just starts level & stays that way to top speed. Changing the trim angle DOES NOTHING to the level running at any speed. Most of us never learn about how important the correct prop is. Quote Link to post Share on other sites
