Alternator test results....
So I posted a pick of my boat gauges while the throttle was wide open. Someone commented that my voltage gauge was showing that my alternator wasn't charging.  I did some testing and this is what I found...
Boat off and starting battery only
12.53v
Started up boat and left at idle
Battery 13.72 and gauge about 12.2
Boat at 2000k RPM
Battery 13.82,  gauge 12.2ish , positive terminal on alternator 14.9 ( connected the negative lead to the house battery negative terminal)
Boat back to idle
12.64 battery and gauge at 11.2 ish, positive terminal on alternator 14.52
Now I didnt think I hand any problems. I was mentioned by another poster that they thought the reason my 496 alarmed at 5000rpm and 56 mph was that it was reading low voltage. ( he was able to see my gauge in the pic). I think it was the rev limiter.
Is it safe to say the alternator is good and my gauge is off?
Does your engine ALWAYS start in1 or 2 seconds of cranking ?  Or does it take longer  ?    Were you using a decent voltmeter to take readings at battery ?   A great way to test if your DCVOLTS are close to being right on the  handheld meter is to measure 1.5 volt & 9 volt batteries.
The variation between the Alternator output screw & at the battery could be a voltage drop due to recharging the battery from the cranking.
The voltage difference between dash gauge  & battery  could be the meter  aging
Excellent gauge Denny. That one will always tell you when the battery SHOULD be charged up. If you see a creeping up & steady current demand ?  Check it out time. Battery or even a loose connection growing.  Ammeters are a great diagnostic tool..  Just like oil temperature.  The old woody boats had temperature gauges of fluids.
Love visual analog gauges.  They give a check of themselves & of what they monitor constantly without key pads & scrolling.
