Stuart Adair Posted November 6, 2020 Share Posted November 6, 2020 Hello all and hope everyone is keeping safe. 5.7 Merc in a 1990 Signature 27 which is on a mooring on the River Avon now, and not in the marina. Do I need to drain the water from the engine as winter approaches? If so, the simplest way I can think of is to use a water suction pump I have at the thermostat housing, or is there a special 'Thing' I have to do? Thanks Stu Quote Link to post Share on other sites
cyclops2 Posted November 6, 2020 Share Posted November 6, 2020 Have you left boats in the water all winter before ? Or is this your first boat ? Quote Link to post Share on other sites
Stuart Adair Posted November 7, 2020 Author Share Posted November 7, 2020 It's our 3rd winter. Year 1 was in the marina where we did nothing, last year she was our of the water for works and this year we're moored on the River itself. Stu Quote Link to post Share on other sites
Rambo Posted November 7, 2020 Share Posted November 7, 2020 If surrounding water does not freeze throughout the winter and you do not have extended spells of temperatures way below freezing, the boat "should" be fine. For occasional spells of below freezing the engine room electric heater is a cheap insurance but you do not have that option when moored on the river. I doubt you can drain the engine and keep it drained while the boat is in water - the water line is most likely somewhere above bottom of the engine water jacket - disconnecting a water intake hose might be an option. There is also a water intake itself and/or an outdrive to worry about if the river does deep freeze. If I were you, I would seek local knowledge - ask around at your local marina. Quote Link to post Share on other sites
SterndriveEd12 Posted November 7, 2020 Share Posted November 7, 2020 I agree with Rambo. Check with the local folks who have been at the same location in past winters. Quote Link to post Share on other sites
cyclops2 Posted November 7, 2020 Share Posted November 7, 2020 Do not forget if the water FREEZES in the sterndrive parts !! NOT good. Tipping up a stern drive might not work . Quote Link to post Share on other sites
RobertHan Posted November 8, 2020 Share Posted November 8, 2020 Draining water from your fuel tank can be hazardous. It can cause potential fires if not done correctly. Having some materials will keep these accidents minimal to nil. Besides protecting your fuel tank from possible damage, you will also need a few materials to keep yourself safe during the entire procedure. Quote Link to post Share on other sites
Dgiles Posted November 8, 2020 Share Posted November 8, 2020 10 hours ago, cyclops2 said: Do not forget if the water FREEZES in the sterndrive parts !! NOT good. Tipping up a stern drive might not work . Sterndrives are always submerged....tipping or not tipping does nothing. Quote Link to post Share on other sites
cyclops2 Posted November 8, 2020 Share Posted November 8, 2020 Not true. The sterndrive is to ALWAYS be stored straight DOWN. If not the Rubber sections can suffer from being folded . compressed all winter. Then opened in a cold building in the spring. Not all rubber will tolerate that kind of treatment Sitting in river water is a Crapshoot. If fast current ? It may take longer to ice inside the the lower unit. If in a shallow sandy / whitish bottom? It will freeze up quicker. Boats moored / anchored do suffer ice rubbing of the gell coat. Next spring it just looks very dull. Like being out in sun all summer. Chalky powder. All winter in sunshine Plus the reflection off the ice or snow is not a good combination for Gel Coat. Quote Link to post Share on other sites
cyclops2 Posted November 8, 2020 Share Posted November 8, 2020 I did a web check of water lows in Willshire. Nov to Feb is - 14F to - 16 F. I would pull the boat. If your boat has ANY vertical side in the water . It will be squeezed by the ice at times. Quote Link to post Share on other sites
