mercruiser alpha1 gen 2 lower drive oil reservoir line
Have a problem with an oil leak either the hose to the bell housing or from the transom fitting. I looked up the merc manual and the hose is shown secured to the transom fitting  by a clamp....mine has a cable tie.(on both  ends of the hose).  I have tried to retighten the tie but dont yet know if that was the problem.
I had removed the drive unit before getting this far. Now after tightening the tie  I have refilled the oil reservior (on the engine). I have pressed the anti dribble valve on the bell housing but no oil dribbles through.  Any ideas please.
i dont want to reassemble everything then find that the tightening of the tie was not successful. I figure that the oil hose full and dribbling when presssed should reveal success or not.
Thanks....i note 7 years ago someone had a similar problem but there is no explanation of  how it was fixed.
  • 1 month later...
