My Volvo Penta, 5.7, inboard motor.
My Volvo Penta, 5.7, inboard motor, starts up, runs for awhile, put boat in water and it runs for an hour then cuts off and doesn't start again until the next day. What's wrong with it? This happened a few times, even after being maintenanced. I had to get a tow yesterday because the battery run down after many start attempts. What should I do here?
21 hours ago, Clemson Chap said:
Sounds like you may be experiencing vapor lock.  Is you blower functioning properly?  Any air vent hoses loose?
 The motor is 2006, Volvo Penta, 5.7 L, Fuel Injection. I had no prior problems with the operation, but I had ordered a new fuel pump last year and I had installed it. Fuel pump comes on and works. Should I try going back to the old fuel pump?  I still have it and I had no problems with the old pump.
I've got 2 boats.  A 1997 sig 31 wth twin 5.7 mercruiser and a ski boat with 350 SBC. All these 3 v8  all basically the same because of age.
Had exactly the same problem as you describe in the 350. Found the problem.  It was a $10 condenser in the distributor. Took ages to pin the problem down.  Ran the motor for 4 hours in the shop before the problem showed itself.
Vapor lock was an issue with Mercruiser NOT Volvo's.  The battery can cause the ECM to shut down.  Volvo highly recommends a starting battery or you will have ECM issues (it's in your engine manual).  Was your fuel pump whining? Have you changed your fuel filter?
Online casino bonus fra danske casinoer Velkommen til Danmarks mest komplette liste med bonusser fra danske online casinoer. Hvis du gerne vil vinde lidt mere på dit casinospil, er du kommet til det rigtige sted. Der er mange gode grunde til at bruge Casinopenge.dk:Let og komplet overblik over casinobonusser: Vi har stillet bonusser og betingelser klart op, så du ikke skal læse igennem 53 punkter for at finde gennemspilskravet for roulette. Eksklusive casinopenge.dk bonusser Eksklusive bonusser Vi har forhandlet ekstra store bonusser, gratis bonusser eller til dem der elsker slotmaskiner - free spins, ved mange casinoer. Sikkert: Du finder kun casinoer, der er godkendt af Spillemyndigheden i Danmark, og derfor ved du, at casinoerne er fair og udbetaler dine gevinster. Vind mere: med vores casino strategi vejledning i blackjack, roulette, spilleautomater og alle de andre spil, viser vi hvordan du vinder op til 99,8% på dit spil. Dansk casino guide Casinopenge.dk har siden 1999 været spillerens side, med klar information om, hvor du får de største bonusser, og hvordan du vinder mere fra casinoer på nettet. Hvis du kan lide, hvad du ser, så husk at tilmelde dig vores nyhedsbrev, så du når at få de bedste bonusser, før casinoerne fortryder. Casino spil og regler Indenfor alle casino spil genrer findes der utallige varianter. På casinopenge.dk kan du finde casino regler, casino strategier og tips til mange forskellige casinospils varianter. Med den optimale casino strategi kan du få pengene til at række meget længere, og dermed optimere dine chancer for at vinde den store gevinst. Blackjack og Roulette findes flere varianter. Microgaming tilbyder en blackjack variant med en tilbagebetalingsprocent på fantastiske 99,89%. I roulette er der der en europæisk og en amerikansk variant. Her bør du vælge den europæiske version, da den kun har ét grønt felt med nul, hvilket giver dig større vinderchancer. Du kan læse mere indgående om roulette strategier eller gå til roulette oversigten hvor vi har samlet relevant roulette på online casino information. Spil med bedst mulige tilbagebetalingsprocent Når du spiller casino bør du gøre dig klart at der er stor forskel på tilbagebetalings procenten på de forskellige spil. Tilbage betalingsprocenten varierer fra ca. 70% op til næsten 100%. Dermed er der på den lange bane meget stor forskel på hvor mange penge du hiver hjem igen, alt efter hvilket spil du vælger at spille. Hvis du vil spille slotmaskiner finder du oversigt over de bedste tilbagebetalingsprocenter på slotmaskiner her. Selvom man ikke umiddelbart skulle tro det, kan man faktisk optimere vinderchancer på slotmaskiner - så der er god grund til at læse næmere på casinopenge.dk da vi har samlet masser af relevant information til dig der vil have mere for pengene på online casino.
poker regler
casino gratis spins
gratis spins
bonus uden indbetaling
online casinoer
Since he’s disclosed the boat is fuel injected it’s highly doubtful it’s vapor lock.  I’m not familiar when Volvo did away with carbs, but any carbed engine will vapor lock if the engine compartment isn’t vented well.  Boiling fuel in the lines won’t run in any brand.
The difference is Volvo’s fuel lines have always been water cooled.  That is a add on Mercruiser had to create called the cool fuel module
There is a cheap fuel pressure tester you can purchase to check the fuel pressure while running.I would start there.  it is likely either fuel or ignition related, with the most likely culprit being fuel.  Unfortunately, the fact you changed your fuel pumps, doesn't mean they are STILL good.  Have you changed your filters recently?
Start off by checking your fuel pressure, especially while having problems.  Have you noticed your fuel pump being louder recently?
