What should be paid attention to in the daily inspection of rubber fenders
Concerning some things that should be paid attention to during the use of marine rubber fenders, the daily maintenance and inspection work must be done well.
1. Pay attention to check whether the fender is damaged and the air pressure is normal.
2. Check whether the surface of the fender rope has sharp things which will cause damage to the rubber fender.
3. Check whether the foot bolts of the fender and the bolts which fix the impingement plate are loose. If there is a loose, after tightened,it should fix the fixed bolt and pads through the welding method.
4. Check whether the impingement plate has the phenomenon of depression, cracking, corrosion, in order to prevent getting rust, the anti-corrosion treatment should be carried out once a year as much as possible.
5 Check whether the impingement plate has an anteversion which will easily be caused by the accumulation of materials on the inner side of the impingement plate.
6. Check whether there is scratching on the impingement plate, if so, it should be replaced in time.
7. Check whether the rubber elastic parts which will be lifting the impingement plate have an abnormality, timely treatment and replacement should be done for any abnormality.
