CARMELHILL
My neutral button on my Quicksilver
3 posts in this topic
My neutral button on my Quicksilver 3000 shifter sticks. I'll take the cable off the engine, push i tback and forth, until it releases. Then after reattaching it I can get maybe 3 or 4 throws of the throttle while pushing the neutral in and out, until it sticks again.
Does anyuone know where I can find the manual for this shifter so I can take it apart? My friend thinks it needs lubricationm inside the throttle handle. I only see on screw on the inside of the lever.
Could be the button itself that is broken. Push the button in, and place the handle to wide open throttle. Remove the button by then inserting a flat headed screw driver behind the button, and pulling out. There was a MerCruiser service bulletin about some of the shifters from that era failing. MerCruiser SB 96-13. Have no idea if your controller falls under this recall. Also, taking the shifter apart is often futile. A MerCruiser dealer should have the manual you need, manual # 90-814705R2.
I recomend replacing the entire shifter and cables with MerCruiser Gen II panel shifter and Mercury Gen II Platinum control cables. Take a look at the 2008 Chaparral's for the style of MerCruiser shifter. The handle is easier to use compared to 2007 and older models. Will make a huge difference in shifting and throttling quality. The Commander 3000 shifters can be fun to line up properly where the bezel plate meets the shift box; if not properly aligned, then the shifting/throttle quality sucks.
In short, I do not like the Commander 3000 or Commander 3000 classic shifters compared with the new Gen II units. This is the kind of scenario we run into every summer, and changing the shifter and cables is the best remedy, but is not cheap.
Chris
Gordon Marine
1000 Islands
Chris
I had a similar problem with mine. The dealer replaced the whole unit, indicating that sub-components weren't available. I don't recall the exact price but, it wasn't cheap.
