Blower Quit Working
  • Please log in to reply
7 replies to this topic
#1 MonkeySeaII
MonkeySeaII
    Monkey Sea 2
  • Members
  • 2,469 posts
Posted 24 October 2010 - 05:37 PM
Winterizing my 256 this weekend, had the engine running with the blower while I fogged the engine. Shut everything down, waited a while, then changed the fuel filters. Lot of gas fumes so I figured I'd flip on the blower just to help clear out any fumes down in the bilge. Now the blower won't run!! The light on the switch comes on but nothing! Checked the breaker and it's not tripped. Any ideas?
Lake Wallenpaupack PA
'07 256 SSi
(496 Mag, B3, Corsa Exhaust, K&N Arrestor, Bennett Trim Tabs)
'08 Silverado 2500HD (Duramax Diesel, 6" Fabtech Lift, Edge Evolution Tuner)
#2 professor48
professor48
  • Members
  • 1,940 posts
Posted 24 October 2010 - 05:54 PM
First check the blower switch itself. A wire may have come loose. The light is separate from the blower feed. If they're OK, check your wiring connections. You may have stepped on one while working in the engine bay, pulling it apart. If they're all OK, disconnect the vent hose at the blower. With the switch OFF, see if the fan blade will turn. Check if any debris got sucked up into it. If that's all clear, try disconnecting the positive wire leading to the blower and connecting it directly to the positive side of the battery. If it now works, check the blower switch. If it doesn't, your blower motor went. My first guess is a disconnected wire, either at the switch or the blower (blower more likely). My second guess is debris in the blower itself. Good luck and let us know what you find. Hy
professor48
#3 Toddler
Toddler
  • Members
  • 8,319 posts
Posted 24 October 2010 - 11:05 PM
Do you have an auto fire extinguisher mounted in the engine bay?
If so, Try checking the connections to the fire extinguisher if the wire is loose or disconnected it will not allow the blowers to run.
matt
Matt
2006 256ssi, 496 BIII, Blue
6 Saturdays & a Sunday
2015 GMC Yukon XL,  Red
1289048d-e3de-49d5-9304-53397787d69f_zps
"Too much of anything is bad, But too much good whiskey is barely enough"
Mark Twain.
#4 MonkeySeaII
MonkeySeaII
    Monkey Sea 2
  • Members
  • 2,469 posts
Posted 25 October 2010 - 07:38 AM
matt
Oh, that's good info! I had unscrewed the bracket and moved the tank in order to gain better access to the bilge. I may have knocked the wires loose? Thanks!
'07 256 SSi
#5 professor48
professor48
  • Members
  • 1,940 posts
Posted 25 October 2010 - 08:19 AM
Toddler: Thanks for the info. I didn't know that the blower circuit was in series with the built-in fire extinguisher. I had never had a boat with a built-in extinguisher before the present one and I do not have a manual for the extinguisher system. I'll keep that info in mind for future reference. Hy
professor48
#6 Toddler
Toddler
  • Members
  • 8,319 posts
Posted 25 October 2010 - 09:58 AM
If you have the blowers on and you have a fire in there. It will suck air in making it worse and suck the powder out; which in turn doesn't do any good either.
Don't thank me thank the "Forum" who told me about it.
matt
Matt
Mark Twain.
#7 Randy
Randy
    Captain STCA
  • Members
  • 2,253 posts
Posted 26 October 2010 - 08:22 PM
It seems like I was told that these motors have a thermal cut-off (like when you run them too long). just a thought....good luck
Randy
Posted Image Posted Image
Abbie Ruth
Canyon Lake, TX
2001 Sunesta 232
5.0 Merc EFI, Alpha
"Error of Opinion may be tolerated where Reason is left free to combat it." - Thomas Jefferson
#8 MonkeySeaII
MonkeySeaII
    Monkey Sea 2
  • Members
  • 2,469 posts
Posted 11 November 2010 - 12:46 PM
matt
Thanks for the tip--that's what it was. Took me 2 minutes to find the wire that was disconnected from the fire extinguisher.
'07 256 SSi
