Propeller
  • Please log in to reply
6 replies to this topic
#1 AR0521
AR0521
  • Members
  • 29 posts
Posted 16 December 2010 - 12:37 PM
Just bought boat new (215ssi) in May 2010, when I brought the boat for winterization dealer suggested to send out propeller to be resurfaced. I wasn't sure if it was worth it but agreed anyway, it cost about 150.00 including removal and hub, any opinions on this ?
2010 215 SSI Cuddy 4.3 Volvo Penta
#2 Toddler
Toddler
  • Members
  • 8,315 posts
Posted 16 December 2010 - 12:57 PM
Well is it a Single, or Dual Prop? Aluminum or Stailess Steel? Did it have any dings or gouges in it?
When I had a Alpha Drive using an aluminum prop. I would replace it every-other year cause the small dings it would get in it. 30-40 bucks per-blade to repair vs 130 bucks to replace, keep the old one for spare. When I had three, I would sell the old one on ebay for 20-30 bucks.
matt
Matt
2006 256ssi, 496 BIII, Blue
6 Saturdays & a Sunday
2015 GMC Yukon XL,  Red
1289048d-e3de-49d5-9304-53397787d69f_zps
"Too much of anything is bad, But too much good whiskey is barely enough"
Mark Twain.
#3 AR0521
AR0521
  • Members
  • 29 posts
Posted 16 December 2010 - 02:30 PM
It's a single aluminum prop, it wasn't clean, hit some low water in the NJ bays, scratched but not bad. Dealer explained that boat performance would decrease as the prop deteriorated and it sounded reasonable.
#4 ___
___
  • Members
  • 3,571 posts
Posted 16 December 2010 - 04:13 PM
Prop condition does have a big affect on performance and efficency, so it's important to be maintained.
A new prop with hub kit for a Merc application would cost a little more than what your dealer is charging.
But they're sending the prop out and performing some labor, so it sounds pretty normal. B)
Honorary 180 Club Member #1
#5 Pops
Pops
  • Members
  • 403 posts
Posted 17 December 2010 - 04:47 AM
I would get a new one and install it. Then take old one and just touch up the rough parts with a file or Dremmel to smooth them out and sharpen the edges and then paint it up and have a decent spare. That way, if you kabong your prop, you could do a "field replacement" and get home on the cheap..... Just my opinion on what I would do.
'92 2550 SX Sport
454 Bravo 1
USCGAUX
#6 covedog
covedog
  • Members
  • 176 posts
Posted 17 December 2010 - 01:53 PM
Definitely get a new prop and clean up and save the old one as a spare. I don't know what engine and outdrive you have in your 215, or how you use your boat, but my 2010 215 with the Volvo 4.3 performs decently with the standard Volvo 4 blade alum prop (and the new price for an alum prop is only about 100 deer more than your repair price).
There are also some very good high performance stainless steel props out there that would be worth considering if you want to squeeze out some more performance although many more deer. If you consider changing the prop type, it's best to test various models, if you have a dealer that lets you test props. Prop performance varies depending on the boat they're used on.
Covedog
2010 215 ssi with Volvo 4.3L GXi MPI SX
2001 Porsche Boxster S - doesn't pull boats but sure makes you smile when you can't be boating!
#7 brick
  • Members
  • 3,916 posts
Posted 01 January 2011 - 01:33 PM
Get a new prop, keep the old one as a spare. Before buying the new prop, decide if the performance of the existing prop is what you want. Does it get close to the recommended RPM at WOT?
80B37342-775E-4695-8474-D05C8FE30D98_zps
cute wife
2005 220SSi
350 MAG MPI/B3 2.0/24's
New Dimension tower
C6 Corvette (when not boating)
