Fuel pump whine
  • Please log in to reply
11 replies to this topic
#1 harleybob
harleybob
  • Members
  • 20 posts
Posted 04 November 2011 - 01:59 PM
Hi all This is a 2011 246 ssi. With a volvo penta 5.7 GI 300 hp fuel injected. The boat has only 11 hours. I am hearing a whine comming from the fuel pump. local mechanic says common problem. He says as long as the boat is running fine wich it is not to worry. All imput greatlly appreciated. Thankyou. bob.
#2 better_when_wet
better_when_wet
  • Members
  • 944 posts
Posted 04 November 2011 - 02:11 PM
I think the key word there is "PROBLEM" with a 2011 boat and 11 hours there shouldn't be any PROBLEMS. Might just be me but you don't spend that kind of money to settle on anything. I would make them replace the fuel pump. :Twocents:
P1010564-1.jpg2006 256 SSI 6.2 L Bravo III
2008 GMC Sierra 2500 HD Duramax
1999 Jeep Wrangler
#3 NativeAz
NativeAz
    180 Club Member #3
  • Members
  • 1,379 posts
Posted 04 November 2011 - 02:17 PM
This is a new boat under warrantee?
When you say local mechanic, are you referring to Chaparral dealer/service folks who are perfoming the warrantee service, or local mechanic (marine?) nearby?
Fuel pump "whine" is a loose term. Fuel pump will make normal noise (whine), but certain whines are not normal and mean problems.
You don't want to have it fail on the lake, and it appears you are trying to find out what it is and have it taken care of.
Hopefully the mechanic is certified and has experience.
:drinkinBuddies:
NativeAz
Boatless
1999 Silverado 4WD
I'd rather be sitting in my boat with a drink on the rocks, than sitting in the drink with my boat on the rocks!
Posted Image
#4 Malcolm
Malcolm
  • Members
  • 283 posts
Posted 04 November 2011 - 03:15 PM
My fuel pump inlet was dirty, full of crud. My fault because I used the wrong filter on the tune up before. I held the pump upside down and sparyed carb cleaner into it until I could see the brass screen again,put it all back together again and no more whine. Not sure what to say on a new boat with only 11 hours. I think I would want a new pump and a new filter, then go from there. Fuel pump noise is fine...a whine, not so much!
West Coast Canada
'Black Pearl" 2000 Signature 240
Volvo Penta 5.7 GSi D/P
#5 Weekend At Bernie's
Weekend At Bernie's
  • Members
  • 482 posts
Posted 04 November 2011 - 03:25 PM
The pump should be cool to the touch. If it's hot, you're on borrowed time.
2006 Signature 310
#6 Whalersailor
Whalersailor
  • Members
  • 1,833 posts
Posted 04 November 2011 - 04:21 PM
I have a soft whine when mine is running, but yours sounds like it's pretty loud and mine is also 6 years old. You should not have to deal with it until it fails on you while your out with the family.
Clayton
West Chester, Pennsylvania
Avalon, New Jersey
Northeast, Maryland
2005 Black 256 SSi. 350 MAG, MPI, Bravo-3.
2011 Venture I-Beam bunk, dual axle/surge disc
Tow Veh. 2010 F-150 4x4 Lariat Crew Cab
The ebb and flow of the Atlantic tides
the drift of the continents and
the very position of the sun along its ecliptic.
These are just a few of the things I control in my world.
Go Navy!
#7 Richard W
Richard W
    Always Learning
  • Members
  • 3,613 posts
  • Location:ON Canada in Summers, FL USA in Winters ... :)
Posted 04 November 2011 - 08:04 PM
FWIW ... from a Volvo Penta bulletin posted recently somewhere on this forum:
Noisy Pumps
Electric pumps will often cavitate and become
noisy if they are starving for fuel.
Before replacing low-pressure pumps (carbureted
engines, fuel cells) check the fuel supply, condition
of the fuel hose, anti-siphon valve
operation, and fuel filter before replacing the fuel
pump.
A noisy high-pressure pump on a fuel cell may indicate
a low fuel level in the reservoir. Check the
fuel supply and low pressure pump operation to
be sure the reservoir is receiving the correct volume
of fuel.
This information may prevent needless pump replacement
and reduce the down time for the boat
owner.
Best ... Richard
Have a boat called "anytime", 2007 Chaparral 270 Signature, with
VP 8.1Gi-H 375hp and 1.78 DPS-A with F4 duoprop, cruising
Saint Lawrence River and Lake Ontario in USA and Canada
#8 1slowhoe
1slowhoe
  • Members
  • 461 posts
  • Location:20+ years serving the Greatest Nation on Earth
Posted 05 November 2011 - 04:12 AM
If this is a new sound, meaning hours 1-10 you didn't have it, then call your local chap dealer and tell them you will be dropping it off for a replacement pump. I wouldn't phrase it in the form of a question. Make it a statement.
'09 236 SSX, 5.7, B3, 62 hours.
The most efficient part of any engine is the nut on the throttle.
#9 jeff
jeff
    Commander of the Pacific Fleet
  • Members
  • 8,927 posts
Posted 05 November 2011 - 11:57 AM
I had to replace a Volvo fuel pump at less than 50 hours. I lost the low pressure side pf the pump, and I could tell it was on the way out; not just because the pump developed a rather loud whine, but the engine performance was affected (lost performance over 2500-3000 RPM).
I would have your dealer replace the pump under warranty.
2006 Signature 290 "Shock Wave"
twin 4.3L Volvo Penta OSi engines
twin XDP composite outdrives now Ocean X drives...finally
Boating out of Long Beach, CA
#10 Richard W
Richard W
    Always Learning
  • Members
  • 3,613 posts
Posted 05 November 2011 - 01:23 PM
+1 ... whatever the problem is, it's most likely a warranty issue ---> see the dealer.
Best ... Richard
#11 harleybob
harleybob
  • Members
  • 20 posts
Posted 07 November 2011 - 01:36 PM
Thanks everyone for all the replys. I found a volvo penta dealer who is aware of this problem. he tells me after 2 updates with these fuel pumps they should be ok. He tells me the earlier fuel pumps after being replaced started the whining sound after about 10 hours. I will reply with updates after repair. Thanks again Bob.
#12 El Coqui
El Coqui
  • Members
  • 795 posts
Posted 07 November 2011 - 02:36 PM
Before you go off replacing anything verify your starting procedure.
1. Turn the key to the on position without starting the engine.
2. You will hear two beeps
3. Listen for the pump, it will whine for about 5 seconds while it primes itself. This will prevent the pump from starving for fuel while itís running.
4. Once it stops whining you can start the engine.
If you still have a problem then itís time to see the dealer.
El Coqui
Woodbridge, VA
2007 330 Chap Sig
Ocean-X drives
2010 Lamborghini Murcielago
2011 Z06 Corvette
2011 Bentley Continental Super sport
2012 Aston Martin V12 Vantage
Not really I only wish I had them… just poking a little fun at all of you that list everything with an engine on your profile.
Posted Image
