Jump to content
engine question
  • Please log in to reply
7 replies to this topic
#1 viking1978
viking1978
  • Members
  • 35 posts
Posted 15 April 2012 - 08:54 AM
Hey all-I own a 2005 SSi with a Volvo 4.3. I just purchased the boat last Labor Day, and only had it in the water a few times. But the few times I had it in, whenever I would turn the key off, the motor would run-on or diesel. I have had people tell me it's a timing problem, and others say it's a carb problem. Any help would be appreciated. Thanks...
Posted Image
2005 190 ssi with 4.3 Volvo Penta
#2 PAT
PAT
  • Members
  • 64 posts
Posted 15 April 2012 - 09:54 AM
Try a colder spark plug or a higher octane gas first.
#3 Firemedic555
Firemedic555
  • Members
  • 338 posts
Posted 15 April 2012 - 10:20 AM
What octane are you running now ?
Chinese Proverb: "When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others."
1997 Chaparral 2130 Sport, Limited Edition
5.7L Mercruser, AlphaOne GenII
2004 Ford F150 Supercrew 4x4
NE Georgia, USA (Nottely, Chatuge, BlueRidge, Lanier)
Posted Image
#4 Shepherd
Shepherd
    First Sea Lord
  • Members
  • 3,822 posts
Posted 15 April 2012 - 02:09 PM
Could also try idling the engine for say 20 seconds before turning it off, especially if you're pulling a tube or water skiers, etc. Hot spots on the cylinders combined with a carb set-up and tightened emissions can make for some frustrating times with run-on, aka dieseling.
As others have said, try switching to a high octane fuel first.
If none of the above tricks work, then the engine timing and carb set-up will have to be checked, along with possibly going with a colder range thermostat, and mayhap colder range spark plugs.
The most important things in life aren't things.
Anthony J. D'Angelo
Posted Image Posted Image Posted Image
#5 viking1978
viking1978
  • Members
  • 35 posts
Posted 16 April 2012 - 10:02 AM
I run regular unleaded, which I believe is 89 octane. I will try these suggestions when I get her back in the water next month. Thanks everyone for your input.
Posted Image
#6 professor48
professor48
  • Members
  • 1,915 posts
Posted 16 April 2012 - 02:31 PM
Many marinas and gas docks only carry high test and diesel because that covers most boat engines. If you're trailering, you have other options. First, try upgrading to 91 octane. That may solve your problem, simply because today's gasoline is not the same as gasoline was seven years ago. Good luck. Hy
professor48
#7 Pops
Pops
  • Members
  • 275 posts
Posted 17 April 2012 - 04:07 AM
Or look for a vacuum leak somewhere on the intake. What is your idle speed? If too high, that'll do it too.
'92 2550 SX
7.4L Bravo
USCGAUX
#8 Texascrew
Texascrew
  • Members
  • 281 posts
Posted 17 April 2012 - 09:45 PM
My 5.0 did the same thing the first few times out. I think it was just old gas in the tank from the previous owner. After a few top offs, it hasn't done it since. I never did get the tank very low, so I still had a little bit of old fuel every time I filled it up. The ONLY problem I've had with a "fuel efficient" V-8 powered boat is that it never used enough fuel on a weekend to get the old gas out.
2001 186 SSI Merc. 305 Alpha 1 HighFive Prop
Proud "180 Club" Member #10
Posted Image
Action shots soon to come...
