Trailer Tie Downs - How many and Which ones
  • Please log in to reply
17 replies to this topic
#1 mrvideo
mrvideo
  • Members
  • 162 posts
Posted 07 March 2013 - 11:56 AM
Hi
I am getting a 256 SSI and a Loadrite trailer.  I need to supply tie downs.  Which brand of tie downs are you using, and do you have any pictures of them in place ?
Thanks in advance
Mr Video
2008 Chaparral 256 SSI
Volvo  496, with 375 Ponies
Lenco 12x12 w/ Led, (3) Lumitec Seablaze X blue
Garmin GPSMAP 741xs
Standard Horizon Fixed Vhf
2009 BMW M6 Rag Top
  5 Ltr V10 w 500 Ponies
#2 Jjlai724
Jjlai724
  • Members
  • 1,070 posts
Posted 07 March 2013 - 12:23 PM
You just need two tie downs for the back.  They will attach to the u-bolt on the back of the bolt to the trailer somewhere around the tail light area.
You can get them anywhere form Walmat, Bass Pro, and West Marine.
I use the buckle style versus the ratchet or retracking models.
http://www.basspro.c...oduct/10211385/
1999 2835 twin - 5.7 / Bravo III
2000 1950 Lund Tyee 200HP Yamaha
2004 2500 Suburban
2006 3500 Duramax Dually
2008 C6 Z06 Corvette
#3 Phillbo
Phillbo
  • Members
  • 1,135 posts
Posted 07 March 2013 - 12:30 PM
I actually use 3 tie downs. 2 on the stern and one on the bow.
The bow may be overkill but when I tow it's usually long distances over a rough road.
#4 Jjlai724
Jjlai724
  • Members
  • 1,070 posts
Posted 07 March 2013 - 12:58 PM
Oh yeah...forgot about the bow.  Some boats will just have the winch strap and a safety chain on the bow.  But I also have one on the bow as well.  This prevents the bow from bouncing if you don't get the eye of the bow sucked under the roller.
So three is what I use as well.
2004 2500 Suburban
#5 Toddler
Toddler
  • Members
  • 8,314 posts
Posted 07 March 2013 - 01:25 PM
I only use the little chain at the ramp as a safety when launching and retrieving. After that I put a 2" strap on the front eye along with 2 on the stern eyes.
Matt
2006 256ssi, 496 BIII, Blue
6 Saturdays & a Sunday
2015 GMC Yukon XL,  Red
1289048d-e3de-49d5-9304-53397787d69f_zps
"Too much of anything is bad, But too much good whiskey is barely enough"
Mark Twain.
#6 Wingnut
Wingnut
    WINGNUT
  • Members
  • 3,875 posts
Posted 07 March 2013 - 01:31 PM
The bow strap is for me, the most important. I drove a tow truck for years and can't tell you how many boats ended up on the tow vehicle when the winch standard collapsed during a frontal impact. Remember that the rear straps and winch cable are always pulling forward.
W
http://i526.photobuc...mp/P8080017.jpg
http://i526.photobuc...mp/P8080011.jpg
http://i526.photobuc...mp/P8080010.jpg
http://i526.photobuc...mp/P8080006.jpg
http://i526.photobuc...mp/P8080003.jpg
2008 256 SSX
496 Merc HO 425 HP
Bravo III-X Drive
#7 mrvideo
mrvideo
  • Members
  • 162 posts
Posted 07 March 2013 - 02:08 PM
Wingnut,
Thanks for the Pix's.  Was that your boat that dropped ?  Cable Broke ?
Mr Video
Garmin GPSMAP 741xs
2009 BMW M6 Rag Top
#8 Richard W
Richard W
    Always Learning
  • Members
  • 3,611 posts
  • Location:ON Canada in Summers, FL USA in Winters ... :)
Posted 07 March 2013 - 02:14 PM
Just look how haulers secure their cargo ... the more straps the better.
In case of the boat on trailer, the three points at least to restrict the movement in all directions. One on bow and two far apart on stern. A double strap or chain on bow just in case the winch gives up. No straps ... no friction between boat and trailer while moving over uneven road or when decelerating rapidly. No friction ... the boat is flying on its own trajectory.
Best ... Richard
Have a boat called "anytime", 2007 Chaparral 270 Signature, with
VP 8.1Gi-H 375hp and 1.78 DPS-A with F4 duoprop, cruising
Saint Lawrence River and Lake Ontario in USA and Canada
#9 MonkeySeaII
MonkeySeaII
    Monkey Sea 2
  • Members
  • 2,459 posts
Posted 07 March 2013 - 03:17 PM
Yup, as others said: 2 at the rear and 1 at the bow. My trailer came with a buckle strap bolted to the frame of the trailer at the bow. In the rear, I have 2 buckle types. The back of the trailer is almost lined up with the stern of the boat so it's a short, straight shot.
Lake Wallenpaupack PA
'07 256 SSi
(496 Mag, B3, Corsa Exhaust, K&N Arrestor, Bennett Trim Tabs)
'08 Silverado 2500HD (Duramax Diesel, 6" Fabtech Lift, Edge Evolution Tuner)
#10 Phillbo
Phillbo
  • Members
  • 1,135 posts
Posted 07 March 2013 - 03:46 PM
Why not use your chain as well? I use all three up front. Wench strap, chain and a strap. I'm a better to have it and not need it than need it and not have it thinker :)
#11 delaney
delaney
  • Members
  • 1,898 posts
Posted 07 March 2013 - 04:20 PM
  • BBB-08893_med.jpgi think using the Boat Buckles are a good idea. mounts via a bolt and makes for easy install and removal w/ zero handling nice clean look on the trailer.  (2) in the back and i used (1) at the bow to keep it from bouncing.
2012 327SSX, Twin Volvo 8.1L
Boat Name: Oh, Sea "D" II
#12 mrvideo
mrvideo
  • Members
  • 162 posts
Posted 07 March 2013 - 04:23 PM
I see from the pictures you posted, that there are sway bars attached to your hitch.  What is the weight of your boat, that would require them ?  I have been pulling a 3500 lb Grady White and I have a standard type hitch ???
Mr Video
Garmin GPSMAP 741xs
2009 BMW M6 Rag Top
#13 gators5
gators5
  • Members
  • 105 posts
Posted 07 March 2013 - 06:55 PM
+1 on using 3 straps, one on the bow and 2 on the stern. The 256 weighs in around 5000 lbs, with gear and fuel could be pushing 6000 lbs. Buy some straps rated for the appropriate weight to keep the boat on the trailer in case of worst case scenario of an accident.
2009 264 Extreme
Volvo 8.1 GXI 420 HP
DPS A Duo Prop
"Boats are the nearest thing to dreams that hands have ever made."
#14 Toddler
Toddler
  • Members
  • 8,314 posts
Posted 07 March 2013 - 08:05 PM
Well the winch is rated at 1600#, the strape rated at 5000#, that little chain maybe 250# maybe.
This thing tips the scale at 8600# loaded with 1/2 tank of gas, the WD hitch just makes it ride smoother.
Matt
Mark Twain.
#15 Vitamin D
Vitamin D
  • Members
  • 236 posts
Posted 08 March 2013 - 10:32 AM
Something you should keep in mind when buy tie downs for the boat. Be sure to look at the working load limit of the strap. Do not go by the breaking strength of the strap. If you use the working load limit you will never have to worry about one or all of them breaking apart.
Mat, what make is your weight distribution hitch? Where did you get the bracket to make the WDH work with a straight tongue trailer?
2009 Formula 310BR with twin 377 and Bravo 3
2010 Sunesta 264
8.1 Volvo DP
2007 GMC 2500HD with Banks six gun, exhaust, and air intake
#16 Toddler
Toddler
  • Members
  • 8,314 posts
Posted 08 March 2013 - 11:33 AM
It's an "Equalizer Hitch" by Progress Mfg. they also make the tongue adapter for the trailer. I did have to make a little adjustment to the adapter it doesn't stay put.
Give this guy a call, he was very helpful.
Daniel Hicken
Customer Service Lead,
Progress, Mfg Inc.
1-800-478-5578
Formula 310 nice move-up..... :drool5:  :clapsmiley:
Matt
Mark Twain.
#17 Vitamin D
Vitamin D
  • Members
  • 236 posts
Posted 08 March 2013 - 02:52 PM
Matt, thanks for the info about the hitch. I will give him a call.
Cheers
2010 Sunesta 264
8.1 Volvo DP
#18 Wingnut
Wingnut
    WINGNUT
  • Members
  • 3,875 posts
Posted 09 March 2013 - 08:00 AM
They are not sway bars. That is a load equalizing hitch and the bars take weight off the tow vehicle. Boat, engine, and trailer approach 9,000# on a half ton pick-up, but I trailer less than most on flat ground, out in the middle of nowhere.
W
2008 256 SSX
496 Merc HO 425 HP
Bravo III-X Drive
