Greetings,For some reason my engine
  • Please log in to reply
5 replies to this topic
#1 JimmyG
JimmyG
  • Members
  • 5 posts
Posted 03 September 2009 - 06:47 PM
Greetings,
For some reason my engine hatch won't open. I've checked the breaker and battery and everything is good. Not so much as a peep out of it when I push the switch. I removed the screw off access point at the rear of the boat and think I can feel the pull pin. The pin seems really hard to pull and I don't want to break something; wasn't sure if I need to do something special or just pull it really hard. Can anyone please offer some pointers and maybe a reason why my hatch lift won't work. Thanks
#2 JimmyG
JimmyG
  • Members
  • 5 posts
Posted 03 September 2009 - 06:51 PM
duh, I guess I should let you all know it's a 2009 Sig 280....
#3 fredthenuke
fredthenuke
    Future Banned Member of the Chaparral Forum! ;)
  • Members
  • 3,758 posts
Posted 04 September 2009 - 06:40 AM
Did you find the small push breaker for the lift motor under your helm? If so check for 12vdc at the switch OUTPUT when you push the switch with a DVM. if there is 12vdc that was 0vdc before you pushed the switch then the issue is the lift motor or wiring from switch to this motor. The only way to test is to pull that pin (should take a tight pull but not superman....). Then you can check the 12vdc getting to the motor. If it is then replace the lift motor.
2006 Signature 310
Twin Volvo 5.7l OSi with XDP drives ($4000 a year in #%^$&%$ bellows repairs on average)
4.5 out of 5 Muskrats PREFER Chaparral!!!
#4 delaney
delaney
  • Members
  • 1,901 posts
Posted 04 September 2009 - 10:20 AM
I can't help you there, but want to piggy back on the question. Does anyone know if on a sunesta 264 the engine hatch will open without the batteries installed? I assume so but the hatch seems very heavy.
2012 327SSX, Twin Volvo 8.1L
Boat Name: Oh, Sea "D" II
#5 mpm330
mpm330
    Retired Admiral of the United Texas Fleet
  • Members
  • 12,023 posts
Posted 04 September 2009 - 10:32 AM
On the 330, you are in a whole heap of trouble if the lift doesn't work. The first thing I would do on a 2009 280, after checking breaker and battery switch, would be to dial the dealer and tell him to get his self out to the boat to fix it! :pirate:
Here is a LINK to a previous thread on a 330 that had problems. It may help.
Mike
2009 Sig 330
Lady Christina
twin 350 mags / BIII with DTS
Lake Lewisville, The United Texas
"A government big enough to give you everything you want is big enough to take away everything you have."
"The democracy will cease to exist when you take away from those who are willing to work and give to those who would not."
"A wise and frugal government, which shall leave men free to regulate their own pursuits of industry and improvement, and shall not take from the mouth of labor the bread it has earned - this is the sum of good government. ."
Thomas Jefferson
#6 fredthenuke
fredthenuke
  • Members
  • 3,758 posts
Posted 04 September 2009 - 11:46 AM
Oops - i missed the fact that it is a 2009.... First make sure your batteries are all turned ON (this has been the issue from another new boater). Then if that doesn't fix it call the dealer - let him figure it out.
As for the 264 - if it is big and heavy that means it is POWER as in you don't lift it...
2006 Signature 310
